Author Topic: Do 72 280SE use the same engine as SLs?  (Read 2776 times)
bcjm
« on: May 25, 2008, 11:58:54 »
Do 72 280SE 6 cylinders use the same engine as 280SL?  What other parts are worth salvageable?
Re: Do 72 280SE use the same engine as SLs?
« Reply #1 on: May 25, 2008, 14:31:42 »
The engine would not bolt in directly, SLs have different mounting arms the 70 and later sedans used a different auto transmission. stick shift cars had a diffrent gear box too.
Some of the SL compatable parts;
front sub frame, rear axle, transistor ignition box, coil and balast resistors, timing switching relays, under hood component electrical harnesses may not be exactly the same but could be used with some modifications, When parting out sedans, I always cut off as many of the main harness plugs as I could, They always come in handy for making repairs on old wiring, Relays, alternator, starter, brake calipers, steering wheel, interior door pull handles are the same as USA pagodas with the soft door pockets. The Kangal magnetic buckle seat belts with some modification can be used in a pagoda, Power steering gearbox, engine oil cooler, I am sure there are more, that I can't think of off the top of my head.
« Last Edit: May 25, 2008, 14:40:32 by al_lieffring »
bcjm
« Reply #2 on: May 25, 2008, 21:39:49 »
Can the engine be used with the SL mounting arms?
« Reply #3 on: May 25, 2008, 22:10:12 »
Yes it can.
« Reply #4 on: May 25, 2008, 22:19:25 »
Other items include front brake calipers (basically entire front axle as Al mentions below), fuel feed pump, fuel sender, fuel pump cover, all parts of the steering, side view mirror, rear-view mirror, headrests (and railings inside seats), side marker lights,
