Author Topic: TEMP GAUGE  (Read 5082 times)
ANDREW
TEMP GAUGE
« on: June 10, 2008, 07:28:03 »
I have a 1965 230sl and the temp sender/gauge is apparently all one unit. The copper pipe that connects the two is broken off near the sender and therefore does not work. Does anyone have any ideas for a solution for this. Mercedes will refurb the old one for a little over a twelve hundred pounds but I cant justify this sort of outlay. I dont want to fit a non period gauge and would like to keep it looking original if possible.
Desertpagoda
  • USA, AZ, Tucson
Re: TEMP GAUGE
« Reply #1 on: June 10, 2008, 07:37:01 »
Send both pieces to Palo Alto Speedo in California and ask Hartmut to fix it. Around $200US. They will do all kinds of repair/restoration/upgrade on guages & clocks Ive used them a hundred times  kb
www.paspeedo.com
kb
Re: TEMP GAUGE
« Reply #2 on: June 10, 2008, 07:41:37 »
Hello and welcome,
The Farenheit gage is big bucks but the centigrade one is a lot cheaper. Exact fit, just different calibration.
Actually, prices have changed and are about the same at SLS:
See section 54a, instruments.
« Last Edit: June 10, 2008, 08:00:27 by naj »
Re: TEMP GAUGE
« Reply #3 on: June 10, 2008, 09:07:01 »
Andrew,
I see this is you first post - welcome to the Group!
The first order of business when getting parts or repairs is to shop around.  Here's a list of vendors.  You can sort it by country using the address column.
http://www.sl113.org/wiki/pmwiki.php?n=Suppliers.Start
You can also sort our member list by Country and find your fellow UK members.  Click on their username to send a direct mail and ask where they get their work done or parts ordered.
http://www.sl113.org/forums/members.asp
Re: TEMP GAUGE
« Reply #4 on: June 10, 2008, 16:08:52 »
Get one at a junk yard(or whatever they're called there).  The filled thermal system moves the pointer.  Attach it to the dial.  The dial is either graduated in F or C.  The pointer could care less.  It moves to the same spot at 212F and 100C.  Same one was used on 220SEs, 250SEs, etc in the 50s and 60s.   Or you can send me a mere $1200 plus shipping. Wow, at that price I'll deliver.   Welcome----
« Last Edit: June 10, 2008, 16:11:17 by glennard »
