Author Topic: reasonably priced cocomat  (Read 4443 times)
erb_cid
« on: June 19, 2008, 09:09:27 »
Found a reasonably priced seller of the famous cocomat. He offers  a sweet deal at $250 for the whole set (two front mats, deck mat and trunk mat) with around $10-$20 shipping costs. Im not sure about the quality but this definitely works for my budget.   I recently bought  a later model 1966  230 SL which has a trunck with the spare tire on horitzontal as opposed to vertical position ( I cant remember if it's on the driver or passenger side). The cocomat seller sent me the following drawing  and I wonder if it has the right dimensions for the trunck mat. Grateful for your advice.  :)
erb_cid
Re: reasonably priced cocomat
« Reply #1 on: June 19, 2008, 09:18:05 »
ooops I cant seem to attach the file. I can send you the drawing directly and also send you the contact details of the seler if youre interested
arth
« Reply #2 on: June 19, 2008, 21:18:54 »
have you acually seen a 113 with the spare in the vertical slot in the floor on the left side?  if so that is a very early car as the tire was moved to the right side on a petistal to allow for a larger fuel tank.
in all the years of restoring 113`s i have only seen One.
Art
blue230sl
« Reply #3 on: June 20, 2008, 12:26:30 »
my 64 230sl has the left side vertical well for the spare - and ithas 2 round holes in the bottom that appear to have been drilled out, presumably for drainage, altho there is no apparent rust in the well or the trunk.
« Reply #4 on: June 21, 2008, 06:52:04 »
Where is the "How to attach files" thread?  I can't find it in a search.  We need to make it a sticky thread at the top of the Photos forum.
« Reply #5 on: June 21, 2008, 07:44:54 »
I think it's in FAQs now..
http://www.sl113.org/forums/faq.asp#GetForum
Once you have grasped Peter's weird mind, it's perfectly logical  8)
« Reply #6 on: June 21, 2008, 09:04:05 »
Perhaps you should translate it!  :D
