Author Topic: Incredible disappearing coolant trick  (Read 3726 times)
seattle_Jerry
« on: June 22, 2008, 04:57:55 »
I think about my 220D everytime I listen to cartalk. It had a problem that could just as easily have been on an SL and I never figured it out.
It could go for days or months without needing radiator fluid. I checked regularly and it wasn't a slow leak. It was always full to the brim until it was bone dry.
There was never a puddle under the car.
My guess is that there was a crack in the head or block that sometimes opened and let the water escape.
Any other guesses?
merrill
Re: Incredible disappearing coolant trick
« Reply #1 on: June 22, 2008, 08:41:49 »
where was the puddle located?
could be a failing water pump or maybe your heater core?
did the fluid show up after you ran the heater ?
what was the outside air temp?
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #2 on: June 22, 2008, 09:23:08 »
I recently found a similar slow leak... which accumulated inside the car!  No leaks outside, coolant level would drop slowly over time. I recently found that the heater core bypass valve is the culprit (in my 250SEC). Found thin layer of coolant on the passenger floor board.
seattle_Jerry
« Reply #3 on: June 22, 2008, 16:24:10 »
Thats the thing...there never was any evidence of a leak. No puddles, drips, smell of coolant. It wasn't a slow leak. It was full or it was empty.
