If the leak was coming from the canister-to-housing area, you should double check the seal. Make sure there is one canister-to-housing seal installed. (As apposed to zero or two.)
If the leak was coming from the bolt at the bottom, check the seals inside the bottom of the canister. Hey could be very hard from age and not sealing. Also make sure you are using a washer on the long bolt.
