Author Topic: Center disc on speedo and tach  (Read 3607 times)
Joe
  • USA, CO, Colorado Springs
« on: July 07, 2008, 21:14:22 »
The silver discs in the center of the instruments have fallen off. If I prise off the bezels and remove the glass, can the discs be reattached?
Joe
Re: Center disc on speedo and tach
« Reply #1 on: July 08, 2008, 04:05:37 »
Common problem for these cars. The Discs are glued to the center of the dial and can be re-attached once you have access.
May be time to change the rubber seals between the instruments and the dash if they are dried out...still available at reasonable cost.
Richard M, NYC
