Author Topic: SL 230 Engine Rebuild: Need help!  (Read 6472 times)
MrDevil
« on: July 12, 2008, 04:37:34 »
Sl 230 ,Engine rebuilded
Also fuel injection rebuilded and its working ok.
now i have the problem since i cant put it in correct phase,
I readed an article about injection timing and crankshaft timing.
I need to know the whole procedure including valves
Anyone can help?
« Last Edit: July 13, 2008, 01:55:23 by 280SL71 »
merrill
Re: SL 230 Engine Rebuild: Need help!
« Reply #1 on: July 12, 2008, 06:29:40 »
are you talking about timing the inj pump to the motor?
if so.
1. take off the valve cover and distributor cover
2. turn the motor till the timing on the crank is at zero, rotor is pointing at the  hash mark for # cyl, and the cam notch is up and aligned with the hash mark on the front tower.
3. then turn the crank timing to 20 degrees AFTER top dead center.
4. with the inj pump in your hand, look at the front where the gear is.  this is what you need to time.
5 turn the gear till the notch aligns with the hash mark on the front face of the pump.  I think this is about 10 o clock.
6. put the inj pump on the motor and your are done.
I highly recommend you get the mb cd or a haynes manual.  these will help you out quite a bit.  see one of these for the valve job procedure.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #2 on: July 12, 2008, 13:58:34 »
Which clyinder??
« Reply #3 on: July 12, 2008, 19:07:13 »
Hello MrDevil,
The camshaft turns one revolution for every two turns of the crankshaft. As Merrill has mentioned, make sure the alignment mark on the cam washer is upward along with the cam lobes over number one cylinder. The crankshaft should be turned to 20 degrees after TDC #1.  The marks on the injection pump housing and the notch in the IP spline should be aligned then slid into place. If the distributor is set up properly the rotor will be pointing at the number one cylinder spark plug wire when the crankshaft is at "0" compression stroke #1.
merrill
« Reply #4 on: July 13, 2008, 05:27:25 »
Rod
sorry, the hash mark on the distributor is for the number one cylinder
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
MrDevil
« Reply #5 on: July 14, 2008, 07:15:52 »
And how much mm must register the valves ,anyone has a manual for the valves ?
I made all of work now just timing and my Pagoda will run again like old time :)
 Thanks guys for the help,Really appriciate it.
MrDevil
« Reply #6 on: July 14, 2008, 07:18:07 »
jacovdw
« Reply #7 on: July 14, 2008, 11:51:48 »
If I understand you correctly, you want to know the correct measurements for the valve clearances.
For the inlet valves the clearance would be 0.1mm and for the exhaust valves: 0.2mm
« Reply #8 on: July 14, 2008, 13:30:17 »
0.003" on intake--- 0.007" on exhaust.  The same.
