with our official
Pagoda SL Group logo
from our official partner.
Body, interior, paint, chrome, and cosmetic items
67 230SL Fuel Tank
Topic: 67 230SL Fuel Tank (Read 4063 times)
filipiuk
67 230SL Fuel Tank
July 12, 2008, 09:17:42 »
Can anyone recommend a good place to get a reasonably priced fuel tank for the above?
Thank you. Mike Wilder
Full Member
Platinum
USA, TX, Austin
Re: 67 230SL Fuel Tank
July 12, 2008, 09:46:58 »
Try our supplier page:
http://www.sl113.org/links.asp
Dan Caron (Dr. Benz) has a parts car so he may be able to help with a used one.
filipiuk
Reply #2 on:
July 12, 2008, 11:10:49 »
Thank you. I will check these. Do you know how I can find out what the original color of the car is?
Full Member
Platinum
USA, TX, Austin
Reply #3 on:
July 12, 2008, 12:52:39 »
You should call the Mercedes Benz Classic Center and order a copy of your car's datacard. You will need to provide them with your VIN number.
This datacard should contain all the necessary information regarding the original configuration of the car. You can read more in our Technical Manual:
http://www.sl113.org/wiki/pmwiki.php?n=DataCard.Start
The Technical Manual contains a lot of useful information for new owners.
merrill
Full Member
Platinum
USA, TX, Austin
Reply #4 on:
July 13, 2008, 05:25:31 »
K&K MFG has reproduction tanks. I think they are about 500 bucks.
why are you replacing yours? sometimes a tank can be cleaned and sealed.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #5 on:
July 13, 2008, 13:25:12 »
The 230 tank is different than the 280 tank. K&K only has the 280 tank as a repro. The 230SL tank is only available as a MB part and it's about $1,100.00
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
67 230SL Fuel Tank
