Author Topic: SL Window slides  (Read 2956 times)
Ken Cox
SL Window slides
« on: July 16, 2008, 16:36:00 »
HI All. Found two slides?? inside the door of my 280SL. Looks like they fell off of the track system. Any one know how they work and go back on???
Thanks Ken
(Moved to "Body" forum by rwmastel.)
bogeyman
  • USA, NE, Omaha
Re: SL Window slides
« Reply #1 on: July 16, 2008, 19:19:31 »
Ken:
The large one fits on the rear, small one on front. They fit at the very bottom of the glass - you probably can see glue residue there. I removed the material from the groove and then epoxy glued in some new felt material to the slide and then glued them in place on the glass. If you can get the material off, you can see how they fit on the glass. - if not, I would try to glue them back as is with epoxy.
Rick
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
