Author Topic: Switch on Venturi  (Read 3831 times)
Switch on Venturi
« on: August 03, 2008, 03:40:41 »
There are 2 wires for the switch on the venturi, black/red (pink) and brown/white.  Both have the same size eyelets.  My switch has 2 different screws, one philips (slightly larger head) and one std.
Can anyone help me with which wire goes where :oops: ?  I cant tell which connection on the switch is ground and which is power?  :oops:
Thanks for your help!
Bob  :)
graphic66
Re: Switch on Venturi
« Reply #1 on: August 03, 2008, 07:55:12 »
My car, a 66 230SL, automatic has the red wire on the top terminal and the white on the bottom.
