Author Topic: Kickdown switch  (Read 3253 times)
Kickdown switch
« on: August 03, 2008, 08:57:41 »
Bob, Took out the kickdown switch on a 250SE 4 door.  It is about 10 cm long-from s/w to two male contacts.  It has about 35 mm of 20 mm threads and a lock nut on the threads.  The whole thing screws into the firewall from the engine bay with the lock nut holding it tight. On the 250 -about the first 15 mm were screwed into the firewall threads and the locknut against it, leaving about 8 mm exposed.  Didn't see any plastic pieces--??
« Last Edit: August 03, 2008, 09:04:39 by glennard »
Re: Kickdown switch
« Reply #1 on: August 03, 2008, 15:57:35 »
Thanks Glennard!
Bob  :)
