Author Topic: What is this part? Mystery part....  (Read 6356 times)
scoot
  • USA, CA, Altadena
« on: August 03, 2008, 19:23:57 »
Hello -
I took out the air filter canister because it was rattling and I was trying to figure out if there was a rubber bumper underneith (there was).  While cleaning under the canister I found this _mystery part_.  It's a metric-threaded thing with a rubber hex-head.  I have no idea what it is.   Does anyone have any idea?  See attached photos.
Thanks,  Scott
« Last Edit: August 03, 2008, 19:33:42 by scoot »
Scott Allen
'67 250 SL (early)
Altadena, California
Mark280SL
  • USA, PA, New Hope
Re: What is this part? Mystery part....
« Reply #1 on: August 03, 2008, 20:02:36 »
they look like the rubber buffers that (should) bolt to the side if the canister.
« Last Edit: August 03, 2008, 20:04:50 by Mark280SL »
Mark
scoot
  • USA, CA, Altadena
« Reply #2 on: August 03, 2008, 20:14:08 »
I don't think that's what they are.  On my car there are three rubber buffers -- #1 is on the side facing the fan and has threaded shafts on both ends (and is cylindrical), #2 is the same as #1 but connects to the wheel well and then to a bracket that lets you adjust the canister, and #3 is different -- it is underneither and seemingly held in by friction and the can rests on top of it.   I think it's something else.  I haven't been able to find anything like it when I look at EPCnet for the air cleaner setup.  (On a related EPCnet note, EPC indicates that my car should have an air cleaner that is totally different from what I have.  If I look at the parts for what I have, EPC says they are for a 114 car.  MB Classic Center also sent me parts that have numbers that correspond to a 114 car so I suspect that EPCnet is just plain wrong about air cleaners for my car...)     Scott
Scott Allen
'67 250 SL (early)
Rolf
« Reply #3 on: August 04, 2008, 05:23:44 »
I had the same item lying underneath my air cleaner canister. It had a threaded stud on one end. The other end was straight like in the picture. It looked like something was sheared off. It was to hold the canister to the car. I bought new ones which are different in design with threaded studs at both ends. One bolts from the canister to the wheel well, another from the canister to a bracket, the third bolts underneath the canister to the car. All three studs have rubber which absorb any vibrations. The three all all the same
merrill
« Reply #4 on: August 04, 2008, 07:30:38 »
My 66 has one on the base of the air filter canister as well as the sides.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
scoot
  • USA, CA, Altadena
« Reply #5 on: August 04, 2008, 10:17:45 »
Interesting.  In addition to those three, did you also have a 4th rubber thing under the canister towards the front?  A larger piece that doesn't bolt in?   I suppose it is possible that this piece was somehow to attach to the bottom of the can but it doesn't look at all like there was ever a place underneith for it to attach.  Nor does it look like something threaded was sheered off the other end of the piece I have....     The rubber buffers that I have (2) that have threaded shafts on both sides are cylindrical.  This one is hex.   I'll look again but I'm sure I looked under the canister and searched for a place where a threaded shaft could go.  Is it possible that it only connects to the canister and just "rests" on the surface beneith?   thanks   Scott
Scott Allen
'67 250 SL (early)
« Reply #6 on: August 04, 2008, 11:07:13 »
It's the infamous 'twist off' bumper.  Gotta put pliers on the metal washer, otherwise the washer separates from the rubber.  BMW's have em too.
