Author Topic: servo  (Read 4019 times)
lexsls
servo
« on: August 12, 2008, 10:34:06 »
hi,
does anyone have any pics on how the servopump is attached on the engine?
it's really not working :)
thanks
restoring a '69 280sl
grtz lex
Re: servo
« Reply #1 on: August 12, 2008, 20:38:23 »
Hello grtz,
The power steering pump is held onto it's mounting bracket by two 17mm head bolts behind the pulley in front, one at the rear (14mm lower inside) and the double 10mm adjuster nuts on the side.
Unfortunately, the pulley will have to be removed and most likely the radiator.
lexsls
Re: servo
« Reply #2 on: August 13, 2008, 12:10:58 »
hi,
i know about the three bolts that hold the servo, but where exactly do i have to put the adjuster(s)?
no pics perhaps?
grtz and thnx
