Author Topic: Euro lens gasket  (Read 5885 times)
Euro lens gasket
« on: August 13, 2008, 00:50:42 »
Where I can I get a gasket that's between the lens and the light housing?
« Last Edit: August 13, 2008, 02:23:08 by hauser »
Re: Euro lens gasket
« Reply #1 on: August 13, 2008, 04:29:06 »
MB or K&K sell them
« Reply #2 on: August 18, 2008, 19:12:42 »
Bob, I ordered it from K&K which arrived today.  It seems that Bosch has changed the design of the gasket to one long strip as opposed to a continuous loop.
« Reply #3 on: August 18, 2008, 19:26:35 »
This change probably took place more than four years ago, when I ordered a set. They indeed came in one long seal instead of a loop. I simply installed it such that the two ends pushed against each other at the joint so as to eliminate any leaks from there. Also, I placed the joint at the bottom center of the lens rim.
« Reply #4 on: August 18, 2008, 19:49:51 »
Did you happen to use any adhesive using this seal?
« Reply #5 on: August 18, 2008, 20:20:16 »
None at all.  Once I pressed-fit the entire seal evenly into the groove on the headlight frame, I placed the lens on top, perfected it's position, had a helper push down gently (so the seal compressed a bit), and then affixed the little clips all around the lens and frame.
For lack of better terminology, I believe the "spongeyness" of the rubber creates the seal, under tension.
« Reply #6 on: August 18, 2008, 20:33:20 »
Thanks so mch for the info!  I'm still waiting on the rest of the parts to arrive.  Hopefully I'll have it all done this week.
