Author Topic: Under dash electrical plug mount?  (Read 4194 times)
egggplant
« on: August 15, 2008, 03:01:01 »
The electrical plug for the wires that go up the steering column just hangs under the dash as shown in the attached picture.  Given that the two other plugs in the same vicinity are neatly mounted on a plate, I find it hard to believe that MBZ would just leave the third plug hanging but I haven't figured out where it should be mounted.  Any suggestions?
Re: Under dash electrical plug mount?
« Reply #1 on: August 18, 2008, 18:14:19 »
I believe one side of this connector is supposed to be mounted to an L-shaped plate which is bolted underneath the dash.
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #2 on: August 28, 2008, 11:23:44 »
Hello Graham - - - In the photo you posted one can clearly see a "J" bracket just hanging there empty. I believe that is intended to be a stirrup for the large wire bundle.
Regards,  Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
