Author Topic: replacing electrical connectors  (Read 3668 times)
seattle_Jerry
« on: August 16, 2008, 01:51:50 »
What do you guys do for replacing electical connectors? Generic auto parts store fittings or is there a recommended source?
Re: replacing electrical connectors
« Reply #1 on: August 16, 2008, 05:09:57 »
Hi Jerry,
Here is one source:
http://www.riwire.com/
Bob  :)
graphic66
« Reply #2 on: August 17, 2008, 07:08:03 »
I solder every connection, I don't rely on a crimp only. I like to put a piece of shrink tube on the wire, lightly crimp on connector, then solder it and slide the shrink tube over the solder and shrink it over the spot.That looks to be how all the original connections are done on these cars. Make sure to get electronic solder and flux to avoid corrosion.
