Author Topic: 72 280SE 4.5 REAR AXLE  (Read 3791 times)
hk280sl71
« on: August 17, 2008, 15:12:23 »
I have located a 72 280SE 4.5 rear axle of a parted out car that should be a 3.27 ratio. The seller is not that familiar with the item. Can someone convey where to find the stamping on the differential to verify this.
Pictures would be helpful. The seller is willing to look if he knew where.
Thank you
Howard Kramer
71 280SL
89 911 Carrera Targa
awolff280sl
  • USA, FL, Sarasota
Re: 72 280SE 4.5 REAR AXLE
« Reply #1 on: August 17, 2008, 18:23:06 »
Even when you know where to look, it can still be hard to see. There is a slightly raised plate along the lowermost "rib" on the fixed axle side of the diff, towards the front. You may need some emory cloth or steel wool to see it. There are other numbers on the plate, but the ratio is the last of the numbers, and is kind of scribbled like this: "3,27"
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
