Author Topic: Fan Shroud Stud?  (Read 4919 times)
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
Fan Shroud Stud?
« on: August 18, 2008, 08:58:37 »
On models with automatic, there is a shroud around the radiator fan. At the top and on the forward side of this shroud there is a M5 treaded stud, about 1/2 inch long. What is the function of this stud?
'69 280SL,Signal Red, 09 cam, License BB-59U
'67 230SL, 113042-10-017463 (sld)
'50 Jaguar Roadster XK120, #670.318 (sld)
tired engineer, West-Seattle,WA
awolff280sl
  • USA, FL, Sarasota
Re: Fan Shroud Stud?
« Reply #1 on: August 18, 2008, 09:07:59 »
I think it secures a small bracket that holds the top of the shroud against the upper tank of the radiator. I can take a picture if you want.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #2 on: August 18, 2008, 09:16:19 »
Originally there was a steel strap that hooked under the front of the radiator core, wraped around the top tank and attached to the stud on the top center of the shroud.
This part was obsoleted way back when I worked on these cars, available now?
« Reply #3 on: August 18, 2008, 10:49:13 »
The stud holds a bracket that keeps the fan shroud from rattling on top.
Bob  :)
« Reply #4 on: August 18, 2008, 15:16:33 »
Thank you Bob! That's a great photograph! And you had to take the hood off for me! Thank you very much! I'm going to see if I can buy that strap, if not, I'll make one. That car of yours is in pristine condition! Not even a speck of dust on it! Like it came out of the show room. I'm so envious!
Dave Gallon
  • USA, NC, Statesville
« Reply #5 on: August 22, 2008, 18:43:00 »
Unfortunately, the strap has not been available for many years. I recently inquired with the Classic Center about this item. Also, don't forget the rubber buffers that are used to prevent the shroud from directly resting on the radiator.
Dave Gallon
Gallon Restorations
113.044-12-001155
