Author Topic: fuel mixture  (Read 4105 times)
mrtroya
fuel mixture
« on: August 21, 2008, 07:38:42 »
hi, i have a 67 230sl and got it running (it sat for a couple of years).
it's running rich, fouling plugs and can't get out of it's own way.
Does anybody have a diagram of what does what for the fuel mixture.
Also, how to check fuel pressure?
Also, Im in Westchester NY, lower Fairfield Ct. ant groups or enthusiasts in the area?
jsaylor
Re: fuel mixture
« Reply #1 on: August 21, 2008, 11:43:34 »
Man,
First check out the linkage tour in these forums.  Then do a search for injection pump and read the great info there.  You sould also look at the discussions on CSV (cold start valve).
Good luck
Re: fuel mixture
« Reply #2 on: August 21, 2008, 17:09:18 »
As Jim says, there are various items that influence the fuel mixture. Check the CO level at operating temperature first and foremost; it should be around 3-4% at idle. Easily adjusted with the screw at the back of the fuel injection pump (clockwise to richen, counterclockwise to lean out the mixture) in combination with the large air intake screw on the intake manifold.
This affects the mixture at idle, not at mid- or full-range though. That is influenced by the number of shims underneath the barometric pressure compensator widget sitting on top of the fuel injection pump.
When those two adjustments don't get you to the desired mixture level, chances are the WRD (Warm Running Device) and/or CSV (Cold Start Valve) are not operating properly. You really should diagnose these two first, along with taking the linkage tour as Jim suggests. This is important because how the gas linkages are set up has a significant impact on how the engine runs. Sloppiness or loose connections there need to be corrected. One of the items in that tour is the butterfly valve in the air intake ("throttle body"), that at idle should be closed, to the point of almost binding. ignition timing, and the condition of the distributor, also are of importance in how the engine runs.
It all sounds pretty complicated probably, but with all of the detailed info on this site you will work it all out ...
Re: fuel mixture
« Reply #3 on: August 22, 2008, 20:35:48 »
Hello Man,
My first suspicion would be that the slide valve in the WRD (Warm Running Device) on the injection pump is stuck. Review the "injection pump tour" on this site so you know what and where this item is located. Check to make sure it is functioning correctly.  You'll most likely need a fresh set of spark plugs once you resolve the problem.
Check back if you need more help.
