Author Topic: Radiator hoses  (Read 3253 times)
Radiator hoses
« on: November 07, 2003, 08:11:12 »
I'm about to replace my radiator. Should I do anything special about hoses? Are some better than others?
Shawn Rock
Philly, PA USA
1968 280 SL 4 speed
Re: Radiator hoses
« Reply #1 on: November 07, 2003, 14:43:46 »
I have always heard to use genuine MB hoses and this has come from many sources.  I guess they really last longer and possibly give you a hint of failure (bulging) before failing.
Don't forget how many you have:
- supply & return at radiator
- supply & return at heater core
- supply & return at F.I. Pump thermostat
- supply to overflow/pressure tank
- thermostat bypass
Did I forget any?
« Last Edit: November 07, 2003, 14:47:06 by rwmastel »
Re: Radiator hoses
« Reply #2 on: November 07, 2003, 22:33:30 »
Hello Shawn,
The original hoses are a little expensive, however they will last twenty years or more!
