Author Topic: Shield, Dirt  (Read 4609 times)
Joe
  • USA, CO, Colorado Springs
Shield, Dirt
« on: August 21, 2008, 21:39:43 »
One of my 230SLs is in the shop being painted, and I have a question about the "Shield, Dirt" that is at the lower rear of each front wheelwell. The K&K site has this shield, part number 113-884-01-35, which comes with a rubber gasket around it. This is nothing like what is on my car, so I am wondering how this part works. Do you attach it with screws and then paint the wheelwell, or is it mounted after painting is accomplished? It appears to be some sort of access panel that should be removed to clean out something? If so, then it doesn't make sense to attach it and then spray it with body schutz, or whatever that undercoating is called.
I don't recall anyone on this site mentioning this part before, and apologize if this is old news.
Joe
« Last Edit: August 21, 2008, 23:22:16 by Joe »
merrill
Re: Shield, Dirt
« Reply #1 on: August 22, 2008, 20:58:12 »
check this link
http://www.motoringinvestments.com/MainPage.htm
go to the undercarriage photos , you may find a photo that will help you
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
graphic66
Re: Shield, Dirt
« Reply #2 on: August 23, 2008, 16:38:13 »
Hard to believe that incredible car in the pictures has a cheap clamp on positive battery connector.I hate those troublesome things. It also is just waiting to start a nice fire right where the bare copper can touch the battery holddown. All that work and one wrong part can just glare out on a great looking job.
