Author Topic: The short fuse  (Read 5679 times)
Largeowner
The short fuse
« on: August 25, 2008, 08:59:46 »
I recently burned out my number 2 fuse.  It is the legendary "short" fuse which I gather is NLA.
What is the Pagoda Group approved solution?  Can you remove the spacer and replace with a full-size one?
Large
Re: The short fuse
« Reply #1 on: August 25, 2008, 09:14:58 »
There was some talk about this awhile back. Last time I checked, it was available, though not from every MB parts dealer. As I recall, some referred to it as the "stubby fuse" or "stubbies," so you may want to run a search in this forum with that in mind.
Re: The short fuse
« Reply #2 on: August 25, 2008, 14:37:46 »
I am pretty sure the Classic Center has these. They should be 25 A.
Re: The short fuse
« Reply #3 on: August 25, 2008, 14:38:55 »
I bought a fuse set from SLS recently and all fuses were there.
Bob G MN
Re: The short fuse
« Reply #4 on: August 27, 2008, 09:53:23 »
The classic Center definitely has them.  I got two a short time ago.
Largeowner
Re: The short fuse
« Reply #5 on: August 28, 2008, 11:55:34 »
Call it impatience, call it the march of time, call it inevitable... I drilled out the spacer (took about 60 seconds) and bought replacement fuses at the local Autozone.
For me, convenience trumps "correct" since I am a "driver" and not a "displayer".
Thanks for all the replies,
Large
merrill
Re: The short fuse
« Reply #6 on: November 04, 2008, 20:00:33 »
I just purchased this part from the classic center, it showed up today
part number
072581-025100N  25A short  1.27  each
I bought 2 just in case
contact
Tom Hanson
Mercedes Benz Classic Center USA
Mercedes Benz USA, LLC
949 598-4850
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
jacovdw
Re: The short fuse
« Reply #7 on: November 06, 2008, 03:07:29 »
The short fuse is also available from SLS in Germany.
Item no: 258991
Retails for about 2 Euro each.
