Become a
Full Member
Emergency Contact List
low fuel light
Topic: low fuel light (Read 3570 times)
benzportland
low fuel light
August 26, 2008, 22:04:12 »
I drove to near empty, and the red light came on. Filled it, but now the light continued to come on intermittently, especially when accelerating. Not always, but about 50 percent of the time it comes on. Any suggestions?
Full Member
Platinum
Re: low fuel light
August 27, 2008, 00:26:03 »
Never "tested" my light
Then again, my fuel gauge is currently my odometer: fuel gauge is not working...
awolff280sl
Full Member
Gold
USA, FL, Sarasota
Re: low fuel light
Reply #2 on:
August 27, 2008, 06:12:35 »
I would pull the sender unit and very carefully clean it (I sprayed brake cleaner) to remove any gunk, with attention to the electric contact at the bottom that triggers the low fuel light. Use a new cork sealing gasket.
Andy Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
benzportland
Re: low fuel light
Reply #3 on:
September 15, 2008, 23:37:55 »
Thank you, worked like a charm!! I refered to the tech manual also for tips on removal.
low fuel light
