Author Topic: Tie rod annoyance  (Read 4782 times)
awolff280sl
  • USA, FL, Sarasota
Tie rod annoyance
« on: August 31, 2008, 15:55:52 »
I am unable to turn and adjust the left-hand screw ends of either of the new replacement tie rods I have. The tie rods are screwed all the way into their adjusting sleeves and won't budge. The right-hand screw ends turn easily in the sleeves, but I would have to screw these ones out almost to their ends to match the lengths on my old tie rods. I would like to more-or-less "balance" the number of threads on each end, but maybe I don't really need to anyway. In any event, I can't figure a way to hold the rod and turn the stuck end without risking damage to the tie rod. Anyone run into this?
« Last Edit: August 31, 2008, 18:21:46 by AWOLFF280SL »
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Re: Tie rod annoyance
« Reply #1 on: August 31, 2008, 19:16:06 »
Left and right hand threads??
awolff280sl
  • USA, FL, Sarasota
« Reply #2 on: August 31, 2008, 19:39:48 »
I think so. I believe that one end screws in clockwise, while the other end screws in counter-clockwise.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #3 on: September 01, 2008, 01:36:05 »
Silly question, but did you make sure the cinch bolt is loosened? (on the rod side)
I would soak the offending thread in penetrant overnight, and then use a bench vise for the tie-rod and a pipe wrench for the tie-rod end. Judiciously placed shop-rags should prevent major scratches, etc.  Just make sure you know which way the threads are going!
awolff280sl
  • USA, FL, Sarasota
« Reply #4 on: September 01, 2008, 11:59:06 »
Got it done with a vise and more forcefull persuation. Thanks Waqas.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
