Author Topic: tach installation  (Read 4073 times)
rmmchl
  • USA, WV, Charleston
tach installation
« on: September 05, 2008, 16:34:47 »
i'm trying to get my tach put back in-Really tough-------wrist is all scratched up-Had to stop for now-I'm wore out!  I got the bracket and ground wire on----------Does the cable screw in before or after the bracket is tightned down?---The only way they put these in when they built the cars was to put the tach in first using the middle hole-then putting the center cluster in  using the speedometer hole-then using the radio hole to put that one in-----does anyone have any tricks on how I can complete this-I cant seem to screw the cable in now-I'll undo in at the engine and maybe it will give a little slack
michael romeo
1967  250sl
signal red
Rolf
Re: tach installation
« Reply #1 on: September 05, 2008, 19:14:05 »
I was able to pull some slack on the cable and attach it to the tach after it was tightened, without loosening it from the engine. I had the tach and speedometer out by removing the tach , I was able to reach around the center cluster to remove the speedometer without too much effort. I didn't even cut or mark my hand or wrist doing it.
rmmchl
« Reply #2 on: September 05, 2008, 20:16:14 »
i finally got it-it was pure luck to get the bracket on there correctly-I loosened the cable from the engine and got slack-after me hands healed from earlier todaya, I reained the strenth, and screwed on the cable to the tach-I hate these cars!!!!!!
michael romeo
1967  250sl
signal red
« Reply #3 on: September 06, 2008, 10:16:33 »
Welcome to the specialized world of Pagoda contortionists!
