Author Topic: mystery wire on engine block  (Read 3905 times)
rmmchl
  • USA, WV, Charleston
« on: September 06, 2008, 17:37:00 »
does anyone what the wire is that connects to a bolted on valve of some type on the engine block just below the valve cover on the injection pump side and goes through the firewall---it goes through the same hole as the tach cable on the firewall.   It is small in diameter--------could it be the temp gauge wire?
michael romeo
1967  250sl
signal red
Re: mystery wire on engine block
« Reply #1 on: September 07, 2008, 05:28:57 »
From your description, sounds like the temp gauge wire.
« Reply #2 on: September 07, 2008, 15:18:44 »
I would second that.
P.s. be very ginger with it - it's more aptly described as a 'capillary tube' and contains a gas. Once this gas is allowed to escape you will have to buy a whole new tube at a cost that is not insignificant.
« Last Edit: September 07, 2008, 15:21:03 by cees klumper »
