Update on my recent temp gauge issue. (The capillary tube had completely disintegrated and broke in two.) I ended up sending the center cluster and my speedometer to Palo Alto. The cost for just the temp gauge repair was about 165 -- same price for the speedometer to be serviced and trip meter repaired. Quick turnaround which was nice. They are back home safely and went in today. Speedo went in easily. The temp gauge, however, gave me some trouble. First off, I enlisted my wife to hold the cluster and carefully feed the capillary line as I worked it through the spaghetti from underneath. That part went smoothly. But when I attached brackets, for some reason, the nut on the left had no room to spin on the post. I ended up filling the bracket down to where I could at least get the nut started... that was very strange. Then the tach went in fine.
And what else: a new issue... so I tested the dash lights (new bulbs) and they all came on. However... now my rheostat is not working. The lights are bright which I take it is lucky -- but they do not dim. Once I got done swearing -- I removed tach, then checked wiring as best I could, and put it back in. After that nut job (no not me) I decided not to remove the cluster again.... I suppose I screwed up the rheo along the way? If the lights are on and bright, not much I can do is there? I can live with it but its frustrating as heck to take 2 steps forward and give one of them back...
