Author Topic: New Bosch Fuel Pumps  (Read 5111 times)
Nate
  • Mill Valley, California
« on: September 11, 2008, 15:44:37 »
Has anyone purchased and installed the "new" Bosch fuel pump?  Apparently it's a bit larger than the original and requires a different mounting bracket, bushings, etc.  How has the performance been?
Arabian Gray / Dark Red Leather
2013 Porsche 911 Carrera 4S Coupe
Black on Black
2013 ML350 4MATIC
Arctic White on Almond Beige
Wife's car that I get to drive
1964 Porsche 356C Coupe
Irish Green on Black
Black Plate CA Car
Unrestored
George Des
Re: New Bosch Fuel Pumps
« Reply #1 on: September 11, 2008, 21:20:28 »
The newer, small style pump uses an adaptor bracket to attach to the original cross bracket attached to the frame. It also requires 3 rubber bumpers that have a smaller screw attachment than the original bumpers.
George Des
gugel
    • CPE Site
« Reply #2 on: September 12, 2008, 23:21:08 »
I have a new fuel pump on my car.  It works fine, except that the inlets and outlets are in different places and the bottom of the pump is a bit lower than the original, so the protective can won't fit over the pump without fairly major modification.
Chris Earnest
« Reply #3 on: September 13, 2008, 08:34:20 »
Nate,
This is the precise reason why many of the fuel pump cages on cars are either missing or "butchered"; it was because of the fuel pump replacement.  Rather than do the job properly and change the cage/cover too, thrifty owners and mechanics started taking metal cutting tools to the otherwise sanguine older fuel pump cover, or worse, throw it out completely.  Yes, I was a victim too.
George Des has been offering advice and even parts on rebuilding fuel pumps, so before you invest in an expensive new style pump, you might investigate this and preserve the integrity of your fuel pump cover and also avoid the pitfalls of not having the right adapter brackets and mounting parts.
« Reply #4 on: September 13, 2008, 10:13:10 »
Have a look here (A lot of the information originated from George Des):
http://www.sl113.org/wiki/pmwiki.php?n=Fuel.Pump
« Last Edit: September 13, 2008, 10:14:32 by naj »
Nate
« Reply #5 on: September 15, 2008, 13:31:29 »
Thanks Mike and George.  This is extremely helpful and it's pretty clear I don't want to go with the newer larger size pump.  Thanks for helping me avoid what would have been a big mistake.
Black on Black
2013 ML350 4MATIC
Black Plate CA Car
Unrestored
