Author Topic: spark plugs defective after ±3000 km ?  (Read 5261 times)
Ziggy
« on: September 18, 2008, 12:43:41 »
I fixed a very weird problem today. The engine has been running perfectly but suddenly began misfiring and hesitating when accelerating from idle. Also sometimes it would idle perfectly for a while, the next time it could barely idle at all. I changed ignition wires, coil, checked everything but could find nothing (everything is brand new...)
It was an ignition problem for sure, so eventually I decided to change the spark plugs.
That seemed to be the problem, but...
The spark plugs (ngk bp7es) were only about 3 months old[:0] the gap had not changed, the color was right and they just look new.
What could be the problem ? I am thinking it must be something with the internal resistance of the spark plugs?
« Last Edit: September 18, 2008, 12:44:47 by Ziggy »
Re: spark plugs defective after ±3000 km ?
« Reply #1 on: September 18, 2008, 17:40:56 »
I'm no techie but these are fairly high compression engines and driving moderately can result in fouling...rough idle, rough acceleration, etc.
I'm in New York City and do a fair amount of slow driving.
A run at moderately high rpm for 5 or 10 minutes might clean up the gunk.
When Ole Beige is getting rough, I take her out on a highway at about 50 mph but leave it in 3rd gear so it revs near 4000 rpm for a while...does wonders. Maybe this is all you need???
Richard M, NYC
« Last Edit: September 18, 2008, 17:41:19 by 280SL71 »
Ziggy
« Reply #2 on: September 19, 2008, 10:01:56 »
They weren't fouled. I decreased the gap to about 0,7mm and put them back in, there was still some misfiring now and then, but a lot less. Perhaps it has something to do with this hotter cam: http://index.php?topic=9274
Ulfi
« Reply #3 on: September 22, 2008, 06:46:07 »
A little "Italian Tuning" also does the trick for me - and it's great fun too!!
hill
« Reply #4 on: September 23, 2008, 10:44:12 »
Aren't  BP7es the coldest plug in that range?
« Reply #5 on: October 05, 2008, 07:57:01 »
Yes, Darryl is correct, in most cases we are using BP5es or BP6es are used in these engines.
