Author Topic: fuel mixture or ??  (Read 4437 times)
james
fuel mixture or ??
« on: October 20, 2008, 14:42:21 »
 I am having a real problem with my 230sl. It will not take gas without stubbling just off idle.Move past 2000 rpm's it runs great.
I have checked all of the electronic,timing,points,plugs,wires,cap,roto,and have tryed every timing position possible.
It really seems to be fuel related. Also it backfires through the intake.
I have tried ajusting the fuel mixture and this dosen't seem to fix it either.
any suggestions?
Jim
Re: fuel mixture or ??
« Reply #1 on: October 20, 2008, 15:31:51 »
You might check your throttle linkage set up. Mine was out of adjustment and had similar problems as yours. Once I rebuilt mine, those problems are gone.
MichaelB.
« Reply #2 on: October 20, 2008, 15:59:04 »
You did not mention the condenser. Did you renew that?
james
« Reply #3 on: October 20, 2008, 18:42:37 »
I did not change the condenser. I will.
As far as the throttle linkage. what do you mean rebuilt?? I know there is a procedure for set them up in the book. should I just refer to that and re-set them all?
Jim
jameshoward
« Reply #4 on: October 21, 2008, 02:23:22 »
James,
read the linkage tour on the website. It's superb and probably holds the answer to your problem.
I'd add that it's an art not a science, and that it took me a few attempts (4) to get it right. But when you get it right, you'll know it because you'll hit a sweet spot.
But there's a ton of other stuff to look at, like points, plugs, dwell, timing, etc. There's a great deal of info on the site that might help you attack your problem. I'd suggest a dose of reading before leaping in.
JH
James Howard
1966 LHD 230SL
