with our official
Pagoda SL Group logo
from our official partner.
rear axle swap
Topic: rear axle swap (Read 4969 times)
colinwoodburn
rear axle swap
November 01, 2008, 10:40:02 »
I have tried to get hold of a 108 4.5 se axle with the 3;27 ratio to put into my 280 Pagoda. So far I have only been able to track down the centre diff and casing without the two axle/half shafts attached .Does anyone know if the pagoda parts will mate up to this unit ? I know an axle swop would be easier but "beggers cant be choosers" Maybe I should ask "joe the plumber" Is he here ? Thanks Colin
Associate Member
Platinum
Canada, ON, Port Lambton
Re: rear axle swap
November 01, 2008, 11:29:53 »
Joe has one at my place. It's 3.27 from a 280SE 4.5
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Full Member
Platinum
Re: rear axle swap
Reply #2 on:
November 01, 2008, 11:30:49 »
may be too late but 3.46 axles are easier to get hold of. I can steer you towards a couple complete in the UK from £150
Re: rear axle swap
Reply #3 on:
November 01, 2008, 12:49:34 »
According to MB EPC the 280 4.5 and the 280SL half axles are the same.
Right side 1083500710
left side 1083500310
Full Member
Platinum
USA, OH, Blacklick
Re: rear axle swap
Reply #4 on:
November 02, 2008, 22:17:53 »
Hello Colin,
The left side axel tube casting is different where it meets the gear case. The V-8 gear case is larger.The right side axel tube casting should be the same. The axle shafts themselves are most likely the same.
Dick M
Re: rear axle swap
Reply #5 on:
November 09, 2008, 18:08:39 »
There is an axle available here:
http://video.google.com/videoplay?docid=8503059846546948448&hl=en
rear axle swap
