Author Topic: B pillar door strike interchangeability?  (Read 5552 times)
redpagoda
« on: November 18, 2008, 02:38:13 »
The strikers on the B pillar of my car are worn, not catching the door on the second latch, thus requiring the doors to be slammed shut, something I am not happy about. I have inspected the latch and these are in good condition with no play in them. However the strikers are a little worn with movement in them. The question I have are these the same as similar vintage sedans that I could scavenge parts off?
Anfinn
Re: B pillar door strike interchangeability?
« Reply #1 on: November 18, 2008, 15:45:18 »
The door strike changed design from VIN no ..0002980 of 250-production. Went from 3 fixing screws to 4.
SLS have a good info-page (page 72b) illustrating the different versions, and what they can supply.
« Last Edit: November 18, 2008, 15:49:19 by Anfinn »
« Reply #2 on: November 19, 2008, 03:47:20 »
I found that the strikers from a 220se coupe did fit on my 230sl. I know that the strikers from the 108 and 115 series won't work. A 111 fintail 4 door might be a match, don't know for sure though.
redpagoda
« Reply #3 on: November 19, 2008, 19:08:52 »
The web site at SLS is good in helping identify the striker. Mine unfortunately is the one that appear to be no longer available. The 3 hole 48mm that uses the latch with two catch points. Off to the wreckers to hope to find a compatible unit off some similar vintage sedan
Anfinn
« Reply #4 on: November 20, 2008, 16:33:31 »
If you are willing to drill and tap two new holes at 55mm down from the top ones, you should be able to use the strikers illustrated at SLS as replaceemts .
Items 272020/1
« Reply #5 on: November 20, 2008, 20:20:01 »
Here is a picture of the 3 hole striker. Its a good part # and Germany is showing availability (130.00Euros  :-*).
Can't remember if they're handed ???
« Reply #6 on: November 24, 2008, 05:03:42 »
Looks like there is a NOS on eBay: Item number: 220317790067
