Author Topic: Steering wheel removal /replacement hrs?  (Read 4894 times)
k
« on: December 03, 2008, 21:44:27 »
How many labor hours is required to replace the steering wheel?
It it a simple bolt on job or do you need alignment / centering splines, etc, expertise?
Also, who has best price: seems like $425?
Re: Steering wheel removal /replacement hrs?
« Reply #1 on: December 03, 2008, 22:38:52 »
Simple bolt on job. A few minutes is all it takes, if that. Can't help with price, but they are obscene these days.
69280sl
  • USA, IL, Elk Grove
« Reply #2 on: December 04, 2008, 03:04:03 »
Assuming you mean only the wheel and not the shaft or column, I echo Douglas. A few minutes. If you were quoted $425 RUN, don't walk.
Here's what worked for me:
If you are re-installing the same wheel; before you remove the wheel make matching punch (or other)marks on the shaft and wheel hub so that it goes back to the same spline.
If you are putting on a new wheel, note the position of the old wheels spokes and try for the same with the new. It may take a couple of tries to get it right. Don't tighten the nut all the way till you are satisfied. I left my new wheel skewed because it felt more comfortable to hold with my arm on the door arm rest.
When you re-install, put some tape between the socket and the nut to keep it from falling off before it engages the shaft.
Good idea to punch a dimple between the hub and the shaft for additional assurance against the nut loosening.
« Last Edit: December 04, 2008, 03:18:47 by 69280sl »
Gus
abe280SL
« Reply #3 on: December 04, 2008, 03:55:56 »
..and if you are using any pipes for leverage, roll down your windows.  No it didn't happen to me.
abe
john.mancini
  • USA, FL, Nokomis
« Reply #4 on: December 17, 2008, 19:47:11 »
Once you remove the fenders it should only take about 10 minutes to change out a steering wheel.
John
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Mark280SL
  • USA, PA, New Hope
« Reply #5 on: December 18, 2008, 00:47:24 »
To replace just the stock steering wheel itself it is all of 10 minutes effort, one of the very easiest jobs on these cars.
In the event you want a black one in nice condition I have one I will be selling, I was going to put it on ebay and ask 150.00 + shipping, I'm honestly not sure what a good used one is worth but that seemed ballpark for others I had seen listed and sold. I just have not gotten around to listing it yet.
If you want a new one you can do better then $425.00 if you look around and aren't in a hurry.
Mark
