Become a Full Member and get the official Linkage Tour and the official Starting Aid. This information alone will pay for your membership
Hello,It should be no problem. The two are exactly the same size. The brake issues will be a bit more work, but should be a nice upgrade. Be sure to use the special lube to fill the diff. You may also get the advantage of a better rear gear ratio.
