Author Topic: Who sells an upgraded anti-roll / sway bar (22mm or 30mm)?  (Read 5441 times)
k
« on: December 08, 2008, 16:28:12 »
I searched thru all the threads and contacted the vendors listed, all said NLA.
Millers lists an early 230 SL part, trying to get #mm size.
Re: Who sells an upgraded anti-roll / sway bar (22mm or 30mm)?
« Reply #1 on: December 08, 2008, 18:57:57 »
At one time you could get a custom made one from Cox Racing.  Do a search and you'll find out a little more about it.
k
« Reply #2 on: December 08, 2008, 20:25:22 »
Yep, he replied no
scoot
  • USA, CA, Altadena
« Reply #3 on: December 09, 2008, 15:25:53 »
Did you try SLS?
Scott Allen
'67 250 SL (early)
Altadena, California
k
« Reply #4 on: December 09, 2008, 16:10:49 »
Did you try SLS?
NLA online catalog, will check w. email
response from Millers
The part # 32-2013 is the sway bar mounting kit only and does not include the sway bar itself. The original sway bar for the 230SL has a 22mm diameter but is no longer available from MB in both the U.S. or Germany.
Sincerely,
Miller's East
« Last Edit: December 09, 2008, 17:17:13 by k »
« Reply #5 on: December 15, 2008, 20:26:20 »
K, if you get enough people interested in a larger sway bar there's a remote chance that Cox would do a batch for us.   They did it before perhaps they'll do it again.
« Reply #6 on: December 16, 2008, 07:31:54 »
What about a second hand one off a finnie?
