Author Topic: Horn Pad  (Read 4158 times)
pauldridge
Horn Pad
« on: December 11, 2008, 14:18:34 »
Did some of the white steering wheels come with horn pads with the padded part white, or was this part always the same leather/vinyl color as the upholstery?
Re: Horn Pad
« Reply #1 on: December 11, 2008, 14:55:08 »
The center pad on a white steering wheel was originally a cream color vinyl. They are only in other colors or leather if they have been recovered. I cringe when I see them covered to match the interior, but appearantly other people like it.
pauldridge
Re: Horn Pad
« Reply #2 on: December 19, 2008, 15:13:18 »
Does anyone have experience disassembling the horn pad  (backing, chrome ring, center medallion)?  I want to "refresh" the vinyl part of the pad with some vinyl spray, and would like to take it apart if it can be done non-destrucively.
Re: Horn Pad
« Reply #3 on: December 19, 2008, 16:18:15 »
Search is your friend... and much improved over the old site.  Alfred Esser has written much about it: http://www.sl113.org/forums/index.php?topic=6502.0
Also check the Technical Manual: http://www.sl113.org/wiki/pmwiki.php?n=Interior.SteeringWheel
But if you use the search function (at the top left) and enter " Horn Pad"  you'll find many more relevant topics.
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
Re: Horn Pad
« Reply #4 on: December 20, 2008, 01:34:43 »
Hello Paul - - - Alfred and I worked together on this same little project earlier this year. These photos will be helpful. His is white mine is maroon.
CAUTION: be very careful when unbending the retention tabs of the trim ring. They  break off easily.  I can send you the die pieces like I did for Alfred.
Regards,   Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
