Author Topic: Engine Cleaning Question  (Read 2884 times)
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« on: September 25, 2005, 18:19:50 »
My 280sl engine is filthy. In the pass, I have had a pro steamer clean it. Recently, I bought a pressure washer 1650psi for doing everyday household stuff. Can I use the pressure washer maybe in combo with a decreaser?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
BHap
  • USA, PA, Pittsburgh
Re: Engine Cleaning Question
« Reply #1 on: September 25, 2005, 18:43:45 »
my opinion is simple green, a soft brush and a slow rinse....  i wouldn't run the pressure washer in the engine compartment....  why push all that pressurized water where you don't want it? cover distributor, coil, relays and fuse box with plastic bags - i'm guessing you'll get most of the dirt out this way and not risk water damage to electrics and linkages...
Bob Happe
Pittsburgh, Pa
Bob Happe
Pittsburgh, Pa
« Reply #2 on: September 25, 2005, 19:02:09 »
Let the Search Feature of this forum be your friend.  ;)  Simply entering "engine cleaning" turned up this thread that answers the question best...
http://sl113.org/forums/index.php?topic=3328+cleaning
1973 911S
2004 A4 3.0
2006 GS430
